12.2 Create Repricing Patterns
You create Repricing patterns to capture the Repricing Behavior of instruments whose rates change according to complex schedules.
To create the Repricing Pattern, follow these steps:
- Navigate to Repricing Pattern Summary Page.
- Click Add icon.
The Add Repricing Pattern Page is displayed.
- Enter a Numeric Code Value for the new Repricing Pattern. You can also click Generate Code Option in Code field to generate the code automatically.
- Enter the name of the pattern.
- Type a brief description for the pattern.
- Select the Repricing Pattern Type: Absolute or Relative.
The selection of the Repricing Pattern type determines the fields that are displayed in the Repricing Events Table and the information you must provide to successfully define that pattern type. See:
- Click Save.
