5.2.2.3.1 Define a Hybrid Curve
To define a hybrid curve, follow these steps:
- Select the Source Type as Hybrid in the Hybrid Term Structure tab, and then select the Hybrid Curve Type (Spread, Moving Average, or Merge).
- Select the Interest Rate Codes for the hybrid type and click Apply.
