10.4 Deleting Behavior Patterns
You can delete patterns that are no longer required.
A rule cannot be retrieved after deletion.Restrictions on deleting patterns are:
- You cannot delete patterns if you have only Read privileges. Only users with read/write privileges and pattern owners can delete rules.
- You cannot delete a pattern that has a dependency.
To delete a Behavior Pattern, follow these steps:
- Navigate to the Behavior Pattern Summary page of the pattern you want to delete.
- Search for a pattern. For more information, see the Searching for Rule section.
- Select the appropriate pattern and click Delete
