18.2 Executing Cash Flow Edit Process
Execute a Cash Flow Edit process to check the accuracy and the completeness of your Instrument table data. When run in Preview mode, you can view the results of running a Cash Flow Edits process by querying the FSI_CFE_MESSAGES_MLS table for generated errors before the system updates the underlying records in the Instrument tables.
You can execute Cash Flow Edit process using following methods:
