9.2 Searching for Rules
Search for a business rule to perform any of the following tasks:
- Update, Copy, Delete, or Run existing rules.
- Define methodologies for products or define other processing assumptions
To search for a rule, follow these steps:
- Navigate to the Rule Summary page for the appropriate rule type.
- Select the folder from the Rule Summary page in which the rule is stored.
- (Optional) Enter the name of the rule.
- Click Search button.
Only rules that match the search criteria are displayed.
To search for a rule in Cash Flow Edit, follow these steps:
- Click Search button in the Search area .
- Enter Rule name, description, or select folder, and then click Search.
- When you click Search, depending upon the search criteria, this filters, and displays the relevant search combination parameters under the Rule Summary as a list.
