10.2 Viewing and Editing Behavior Patterns
You can view existing Behavior Pattern, and you can edit existing rules, provided you have read/write privileges.
To view and edit a Behavior Pattern, follow these steps:
- Navigate to the Behavior Pattern Summary page of the pattern you want to update.
- Search for a pattern. For further information, see the Searching for Rule section.
- Select the appropriate pattern and click Edit to open the pattern you want to update.
- Update the Name or Description.
- Click Apply or Save, depending on the pattern type.
