14.3 Balance Computation Migration
The below table provides you the details to migrate the UI configuration from the source environment to the target environment. You must extract the Insert SQLs from source environment and then execute it in the target environment to migrate the UI configuration.
Table 14-6 Balance Computation Migration
| Module Name | Table Name |
| Setup Fiscal Period | FSI_FISCAL_PERIOD_SETUP |
| Legal Entity |
FSI_LE_PERIOD_SETUP FSI_LE_PERIOD_AUDIT_TRAIL FSI_LE_PROPS |
| Revaluation Settings | FSI_REVALUATION_SETTINGS |
| Currency Conversion | FSI_BC_GL_RATE_TYPE_MAP |
| Portfolio Summary |
FSI_PORTFOLIO_MASTER FSI_PORTFOLIO_DIM_MAP FSI_PORTFOLIO_DIM_MEMBERS_MAP |
