4.2.5.1 Batch Maintenance
Batch refers to a set of executable processes based on a specified rule. Batch Maintenance framework within the Infrastructure system facilitates you to create and maintain the Batch Definitions. You can process the Batch scheduled for execution from Batch Maintenance and also from other modules and applications such as Rules Run Framework and Enterprise Modeling respectively. You should have Batch Write User Role mapped to your User Group to cancel a Batch. The Batch Maintenance window displays a list of Batches scheduled for maintenance with the other details such as BatchID, Batch Description, and the editable state of the Batch.
  1. From OFSBCE Home, select the Financial Services Balance Computation Engine. In the Navigation List, select Execution, and then select Batch Maintenance. The Batch Maintenance page displays.
