4.2.5.4 Batch Monitor
Batch Monitor in the Infrastructure system facilitates you to view the status of executed Batch Definitions along with the Task details. You can track the issues, if any, on regular intervals and ensure smoother Batch execution. An event log provides you the real time status of the executed Batches. You must have Batch Read Only User Role mapped to your User Group to monitor a Batch. The Batch Monitor page displays a list of Batches with the other details such as Batch ID and Batch Description. You can search for a specific Batch based on Date range, Module, Status, and Batch Description. The Batches listed in the Batch Details section can be sorted based on the current state as Successful, Failed, Held, or New.
  1. From OFSBCE Home, select the Financial Services Balance Computation Engine. In the Navigation List, select Execution, and then select Batch Monitor. The Batch Monitor page displays.
