4.2.1.2 Business Model Upload
You can upload a new model or update or re-build an existing model to the database schema. The option to upload a Business Model is available based on the existing model in the selected Information Domain.
  1. To navigate to the Business Model Upload Page, from OFSAA Home, select Financial Services Balance Computation Engine, select Administration, select Data Model Maintenance, select Add.
    Figure 4-2 Business Model Upload Page
    For detail procedure about uploading a Business Model and for the latest information, see the Upload Business Model section in the Oracle Financial Services Advanced Analytical Applications Infrastructure User Guide Release 8.1.1.0.0.
    For information about uploading a Business Model using different options, see the following sub-sections in the Upload Business Model section:
    • Model Upload Using JSON / ErwinXML section for the Business Model upload using the JSON (ODM) / ERwin XML option.
    • Model Upload Using DB Catalog section for the Business Model upload using the Database Catalog option.
    • Model Upload Using OFSAA Data Model Descriptor (JSON) File section for the Business Model upload using the Data Model Descriptor option.
