4.2.3 Dimension Management
Dimensions referred to BCE are now identified via unique numeric identifiers, except for data origin, accounting standard and GL account type. These dimensions should not be processed as SCD.Dimension Management within the Infrastructure system facilitates you to categorize data into a single object as a Member; define levels and aggregate data to form the Hierarchies, and distinguish each member by defining the required Attributes.
For latest information about the Dimension Management and Mapped Roles, see the Dimension Management section in the Oracle Financial Services Advanced Analytical Applications Infrastructure User Guide Release 8.1.1.0.0.
