14.1.1.1.5 PARALLEL_DML
Limitations in Using Parallel DML
A Parallel DML operation's lock requirements are very different from the serial DML requirements. For these and other reasons, the database imposes some restrictions on Parallel DML operations.
One such restriction is that while a single transaction can contain multiple parallel DML statements that modify different tables, after a parallel DML statement modifies a table no subsequent statement (DML or query) can access the same table again in the same transaction. For this reason, Parallel DML is disabled, regardless of your parameter settings, for any computation rule that both debit and credit the same table. For computation rules that both debit and credit the same table and which you want to ensure run in parallel, it is recommended that you divide your one computation rule into two rules (one rule for the debit side and one rule for the credit side).Parallel DML cannot be set (regardless of the parameter settings) for any computation rule where the Output tables (Credit/Debit) are the same tables as the Source/Driver tables.
For more information regarding the restrictions on Parallel DML, see Oracle Database Data Warehousing Guide.
