26 Non Maturity Products Model Analysis
Non-Maturity Products Modeling helps you to understand the relation between market and bank rate, how much is core out of total available balance for the portfolio, and how long core will remain with the bank based on Decay Rate Profile
The Non-Maturity Products Model Analysis Summary Page allows you to do the following:
- Create a new Non-Maturity Products Model.
- Searching for Non-Maturity Products Model. For more information, see the Searching for Rules section
- Searching for Non-Maturity Products Model. For more information, see the Viewing and Editing Rules section.
- Copying Non-Maturity Products Model. For more information, see the Copying Rules section.
- Deleting Non-Maturity Products Model. For more information, see the Deleting Rules section.
The definitions based on the search criteria are listed under the List of Non-Maturity Products Model Analysis. This is the search section that contains multiple parameters. You can specify one or multiple search criteria in this section. When you click Search, depending upon the search criteria, it filters and displays the list of Non-Maturity Products Models meeting the search criteria. The Non-Maturity Products Model Analysis Summary Window displays the following columns.
Table 26-1 Non-Maturity Products Model Analysis Summary Window Columns
| Column | Description |
| Name | Displays the Non-Maturity Products Model Analysis Rule's short name. |
| Currency | Displays the Currency for which Non-Maturity Products Model Analysis Rule is defined. One rule can be created only on one particular currency. |
| Folder | Displays the Folder name where the Non-Maturity Products Model Analysis Rule is saved. |
| Created By | Displays the Name of the user who created the Non-Maturity Products Model Analysis Rule. |
| Creation Date | Displays the Date and Time when Non-Maturity Products Model Analysis Rule was created. |
| Last Modified By | Displays the Name of the user who modified last the Non-Maturity Products Model Analysis Rule. |
| Last Modified Date | Displays the Date and Time when Non-Maturity Products Model Analysis Rule was modified last. |
| Status | Displays the status of the rule. Complete, In Progress, or Failed. |
| Action | Displays the list of actions that can be performed on the Non-Maturity Products Model Analysis rule. For more information, see Non-Maturity Products Model Analysis Rule- – Icons and Descriptions. |
The Action column on the Non-Maturity Products Model Analysis Summary Page offers several actions that allow you to perform different functions. The following actions are available for the Non-Maturity Products Model Analysis Rule.
Table 26-2 Table: Non-Maturity Products Model Analysis Rule – Icons and Descriptions
| Fields | Description |
Add
Click Add icon to create a new Non-Maturity Products Model Analysis Rule. |
| Delete | Click Delete icon from Top right corner to delete the Data Creation Process Rule. |
| Refresh | Click Refresh icon from Top right corner to refresh the Data Creation Process Rule. |
| View | Click the Action column and select View to view the contents of a Non-Maturity Products Model Analysis Rule in Read mode. |
Edit |
Click the Action column and select Edit to edit the contents of a Non-Maturity Products Model Analysis Rule in Read/Write mode. |
| Save As | Click the Action column and select Save As to create a copy of an existing Non-Maturity Products Model Analysis Rule. |
| Delete | Click the Action column and select Delete to delete an existing Non-Maturity Products Model Analysis Rule. |
| Dependency Check | Click the Action column and select Check Dependency to check the dependency of an existing Non-Maturity Products Model Analysis Rule. |
