30.2.2 WSA Engine and OFSAA Rate Management
Interest Rate Curves required for Moody's should be set up through the Curve Identifier drop-down list in the Rate Management IRC UI. Moody's requires the following curves to be defined:
- LIBOR (Zero-Coupon LIBOR/Swap)
- TREASURY CURVE (Zero-Coupon Treasury)
- COFI (Cost of Funds Index)
- PRIME (Prime Lending Rate)
It's the user's responsibility to set up the proper curves while using Moody's
libraries. Users can define only one treasury curve / one LIBOR curve / one COFI curve
and one prime curve per currency.
A majority of the deals would be based on LIBOR/Treasury Curves.
