34.2.2 WSA Engine and OFSAA Rate Management
Interest Rate Curves required for Moody's should be set up through the Curve Identifier drop-down list in the Rate Management IRC UI. Moody's requires the following curves to be defined:
  • LIBOR (Zero-Coupon LIBOR/Swap)
  • TREASURY CURVE (Zero-Coupon Treasury)
  • COFI (Cost of Funds Index)
  • PRIME (Prime Lending Rate)
It's the user's responsibility to set up the proper curves while using Moody's libraries. Users can define only one treasury curve / one LIBOR curve / one COFI curve and one prime curve per currency.
A majority of the deals would be based on LIBOR/Treasury Curves.
