7.7 Running a Single Task Using a Batch
From the Batch Execution page, you can run a single task from a batch.
Running a single task using a batch is not a recommended approach and must be done only for debugging a task.
To run a single task using a batch, follow these steps:
  1. Log in as the KYC Administrator. The KYC application home page is displayed.
  2. Click Common Tasks.
  3. Click Operations.
  4. Click Batch Execution. The Batch Execution page is displayed.
  5. From the Batch Details section, select the batch you want to execute.
  6. From the Task Details section, click the Task Mapping icon. The Task Mapping window is displayed.
  7. Retain the tasks you want to execute under the Available Tasks section and move the rest to the
    Set Tasks section.
  8. Click OK. A warning message is displayed.
  9. Click OK.
  10. Click Execute Batch.
