E.5.3.1 Prerequisites for Using Control Data
Before you use control data to test your Behavior Detection installation, the following prerequisites must be fulfilled.
  1. The maximum lookback that control data considers is of 13 months, which is for change in behavior scenarios. Hence, while creating control data ensure that it is spread over 25 different dates in 13 months.
  2. The current day according to control data is 20151210.
  3. Unless specified, set the current date as 20151210, to generate alerts on control data, before running Behavior Detection Platform.
For more information about control data on your site, contact your OFSBD Administrator.
