E.5.3.4 Running Behavior Detection on Control Data
In order to generate alerts on the ingested control data, execute the new scenario jobs. These jobs consists of same template group ID as the scenario ID.
Refer to Chapter 5, “Behavior Detection Jobs.” to get information regarding about running Behavior Detection Jobs.
Important Notes
- Run loaded scenarios with the system date as 20151210 with the following
                    exceptions:
                        - For Portfolio Pumping scenario, the system date must be 20151204
- For Active Trading scenario, the system date must be 20151130
- Check for system errors in the appropriate logs (refer to “APPENDIX A - Logging.”, for more information).
- Run post-processing procedures.
- Close the batch to enable display of alerts in the Behavior Detection UI.
- Log in to the Behavior Detection UI with the correct user credentials.
- Verify that you can view alerts in the UI.
The display of alerts signifies that installation of the system is correct and works as designed.
The alerts that you can view depend on your user privileges.
