E.6.7 Running Behavior Detection on Control Data
In order to generate events on the ingested control data, execute the new scenario jobs. These jobs consists of same template group ID as the scenario ID. (Refer to Behavior Detection Jobs to get information regarding about running Behavior Detection Jobs.)
Important Notes
- Run loaded scenarios with the system date as 20151210 with the following
exceptions:
- For Portfolio Pumping scenario, the system date must be 20151204
- For Active Trading scenario, the system date must be 20151130
- Check for system errors in the appropriate logs (refer to Logging, for more information).
- Run post-processing procedures.
- Close the batch to enable display of events in the Behavior Detection UI.
- Log in to the Behavior Detection UI with the correct user credentials.
- Verify that you can view events in the UI.
The display of events signifies that installation of the system is correct and works as designed.
The events that you can view depend on your user privileges.
