7.1.1.3 “Message Log” Canvas Prompt Filters
You can use a series of Report Prompts to filter the data according to Functional Key Attributes as described below:
Figure 7-5 Canvas Prompt Filters for Standard Dimension
- Processor Execution As of Date (Day): The Execution Period of the Cash Flow Edit process. You can use this filter to isolate a selected timeframe for the analysis
- Cashflow Edits Process Name: You can use this filter to select a specific Cashflow Edit Process value
- Execution Run Identifier: You can use this filter to select a specific Execution Run Identifier value at leaf related to the Cashflow Edits Process
- Account Number: You can use this filter to select a specific Account Number value related to the to the Cashflow Edit Process execution
