5.5.3 Embedded Options Schedule
The Embedded Options Schedule Report provides the analysis capability on the Embedded Options Schedule Table.
You can use a series of Report Prompts to filter the data according to Functional Key Attributes pertaining to the Table Columns Perimeter.
The report displays the underlying data according to the following Charts’ logic:
- Embedded Options Schedule - Number of Records Trend
Total Records Embedded Options Schedule aggregated by AS_OF_DATE.
Granular table records at ACCOUNT_NUMBER level.
Figure 5-27 Processing Instrument Supplementary Data – Embedded Options Schedule
