7.1.1.1 “Rules” Canvas Prompt Filters
You can use a series of Report Prompts to filter the data according to Functional Key Attributes as described below:
Figure 7-1 Canvas Prompt Filters for key Attributes
- Group Name: You can use this filter to select a specific Group value related to the available granular rules
- Subgroup Name: You can use this filter to select a specific Subgroup value related to the available granular rules
- Rule Name: You can use this filter to select a specific Rule value
- Rule Identifier: You can use this filter to select a specific Rule Identifier value
- Rule Condition Columns: You can use this filter to select a specific Condition value related to the available granular rules
