5.3.5 Management Ledger04
The Management Ledger04 Report provides the analysis capability on the Stage Placeholder Management Ledger 04 table.
You can use a series of Report Prompts to filter the data according to Functional Key Attributes pertaining to the Table Columns Perimeter.
The report displays the underlying data according to the following Charts’ logic:
  • Stage Management Ledger04 - Number of Records Trend
    Total Records Management Ledger04 aggregated by AS_OF_DATE.
    Granular table records at FINANCIAL_ELEM_CODE level.
Figure 5-16 Staging Ledger Data – Management Ledger04
