6.2 Viewing Cash Flow Report
To view Cash Flow Report of an account, perform the following steps:
  1. Navigate to the Cash Flow Report Summary Page.
  2. Apply search criteria to get list of account numbers that are available. It is mandatory to select a Process and Execution ID to view the report. Click on an account number to view report.
    The Cash Flow Report is displayed.
  3. Select Input Section. Here, you can view the Input information for the following fields:
    • Instrument Attributes: Displays the Input Data from Instrument Tables for selected ACCOUNT_NUMBER and AS_OF_DATE. Attributes have been grouped into multiple categories to simplify viewing. Select the Category, Version, and Leg Type. Leg Type drop-down list is applicable for Derivative Accounts.
    • Payment Schedule: Displays the Input Data from FSI_D_PAYMENT_SCHEDULE (order by PAYMENT_DATE) for selected ACCOUNT_NUMBER and AS_OF_DATE in Table format. This is applicable if the Amortization type is Payment Schedule (800, 801, 802).
    • Rate Tiers: Displays the Input Data from FSI_D_ACCOUNT_RATE_TIERS (order by rank) for selected ACCOUNT_NUMBER and AS_OF_DATE in table format. This is applicable if the Adjustable type is Tiered Rate (300)
    • Embedded Options Schedule: Displays the Input Data from FSI_D_EMBEDDED_OPTIONS_SCH (order by option_expiry_date) for selected ACCOUNT_NUMBER and AS_OF_DATE in table format. This is applicable if Embedded Options Flag is Yes and the Option Exercise Type is Bermudan.
    • Index History: Displays the Input Data from FSI_D_ACCOUNT_INDEX_HIST (order by INDEX_START_DATE) for selected ACCOUNT_NUMBER and AS_OF_DATE in table format. This is applicable if Index Adjustment Type is not 'Not Applicable' and Index ID is null or zero.
    You can download the data in CSV or Excel format.
  4. Select Output section. Here, you can view the Output information for the following fields:
    • Cash Flow: Displays the Output from FSI_O_CFE_OUTPUT_HIST for selected ACCOUNT_NUMBER, AS_OF_DATE, and EXECUTION_RUN_ID in table format. Here, you can Order by data of the SCENARIO_NUM, LEG_TYPE, SPLIT_ID, RECORD_SEQUENCE.
    • Forecast Interest Rate: Displays the Output from FSI_O_FCAST_IRC_RATES_HIST for selected PROCESS_ID and EXECUTION_RUN_ID. Here, you can Order by data of the SCENARIO_NUMBER, INTEREST_RATE_TERM_DAYS. You can compare the Forecast Rates across the scenario. You can select interest rate from INTEREST_RATE_CD drop-down list. Data appears here if Forecast Rates has been selected in Cash Flow Process and Interest Rate Curve(s) have been selected under Calculation Elements.
    • Forecast Economic Indicator: Displays the Output from FSI_O_FCAST_ECO_IND_RATES_HIST for selected PROCESS_ID and EXECUTION_RUN_ID. You can filter Economic Indicator from Economic Indicator Name drop-down list to display data. You can compare the Forecast Economic Indicator across the scenario. Here, you can Order by data of the SCENARIO_NUMBER, RATE PERIOD. Data appears here if Forecast Rates has been selected in Cash Flow Process and Economic Indicator(s) have been selected under Calculation Elements.
    • Message Log: Displays the Output from FSI_O_CFE_MESSAGES_HIST for selected ACCOUNT_NUMBER, and EXECUTION_RUN_ID in table format.
