2.2 Global Preference
Global Preferences items are used to configure your User Interface (UI).
To update the Global Preferences, follow these steps:
- Navigate to Maintenance and select Preferences.
- Select Global Parameters.
Figure 2-2 Global Preference Section
- Enter following values as described in Table:
Fields Description Date Format Select one value from available list.
dd-MMM-yy
yyyy/MM/dd
MM/dd/yyyy
dd.MM.yyyy
MM-dd-yyyy
yyyy.MM.dd
yyyy/MMM/dd
dd-MMM-yyyy
dd/MMM/yyyy
yyyy.MMM.dd
dd/MM/yyyy
MM.dd.yyyy
dd-MM-yyyy
yyyy-MM-dd
dd.MMM.yyyy
yyyy-MMM-dd
Pagination Count Pagination Records determine how many rows are displayed on summary and other screens. If you select Pagination Records to be 25 records, then any screen displaying results in a tabular format displays a maximum of 25 records. Group Company Legal Hierarchy This displays list of Legal Entity Hierarchies that have been configured in Dimension Management. Select one hierarchy that must be used to identify internal (part of same financial group) customers of the institutions. Currency Rate Provider This displays list of providers of Currency Exchange Rate. Value “Default” is seeded and selected as default.
If you load exchange rates from more than one source like Reuters and Bloomberg then select one which you want the engine to use during processing.
Members of Dimension Rate Data Source are displayed in the drop-down list.
- Is Editable status cannot be turned on since individual users are not expected to modify these parameters.
- Click Save to confirm the changes.
