2.5.1 Cash Flow Process Errors
  • Error: Engine does not process, however sometimes default value can get used for calculations.
  • Warning: Engine may use the default value or given wrong data for calculation, results may be incorrect.
  • Info: Does not impact any processing but results may not be as expected.
The following table stores the processing error messages generated by the engine:
Table 2-9 List of Error Codes for Cash Flow Process
Error Code Error Type Error Message
300 Functionality Not Implemented Error
301 Invalid Data Error
302 Principal Cash Flow Not Handled for this Amortization Type Warning
303 Invalid record: Account Number is mandatory Error
304 Invalid value for Adjustable Type, Fixed Rate used Warning
305 Invalid value for amortization term, Number of months between Origination and maturity date used Warning
306 Invalid value for amortization term multiplier, Months (M) used Warning
307 Invalid value for Instrument Type; Loan Contracts (180) used Warning
308 Invalid value for original term; Number of months between Origination and maturity date used Warning
309 Invalid value for original term multiplier; Months (M) used Warning
310 Missing or invalid data version number. Default value 1 used Warning
311 Invalid value for Model with Gross Rates, account processed with net interest rate Warning
312 Invalid value for Interest Capitalization Indicator, account processed without interest capitalization Warning
313 Invalid value for Include Accrued Interest in cash flow, account processed without using given accrued interest. Accrued Interest > 0 but not used Warning
314 Invalid value for Amortization Type; processed as simple interest or non-amortizing Warning
315 Invalid record: End of Period Principal Balance (CUR_PAR_BAL) is zero or missing; Account not processed Error
316 Invalid record: Accrued Interest Net <> 0 and (Last_payment_date < As_of_date) for Behavior pattern record. Accrued interest may be overstated Warning
317 Original Principal Balance is zero/negative or missing; End of Period Principal Balance (CUR_PAR_BAL) used Warning
318 Invalid record: Behavior Type Code is mandatory Warning
319 Invalid record: Calculation date range is mandatory Error
320 Invalid record: As of Date is mandatory Warning
321 Invalid record: Origination date is mandatory Error
322 Invalid record: Maturity date is mandatory; Account not processed; Warning
323 Issue date cannot be greater than As-of-date; As-of-date used Error
324 Issue date can not be greater than origination date; Origination date used Error
325 Issue date not given; Origination date used Warning
326 Remaining Number of Payments is 1 but Next Payment Date and Maturity Date are different. Payment processed on Maturity Date Warning
327 Invalid value for accrual basis; Processed using 30/360 Warning
328 Invalid value of net interest rate; Processed using 0% interest rate Warning
329 Invalid value for compounding basis; Processed as simple interest Warning
330 Model with Gross Rates Indicator is GROSS but gross interest rate is not given; Processed using net interest rate Warning
331 Current Payment cannot be less than 0; 0 used; Warning
332 Invalid Last Interest Payment date; "Next Interest Payment Date minus Interest payment frequency" used. Warning
333 Invalid next interest payment date; "Origination date + 1" or "As-of-date + 1" used. Warning
334 Invalid original interest payment date; "Origination date + Interest Payment frequency" used. Warning
335 Invalid value for interest payment frequency; Number of months between Origination and maturity date used; Warning
336 Invalid value for interest payment frequency multiplier; Months (M) used; Warning
337 Invalid value for Remaining Number of Payments; Default value 1 used; Warning
338 Invalid Last Interest Payment date; "Origination Date" used. Warning
339 Invalid Last Principal Payment date; "Next Principal Payment Date minus Principal payment frequency" used Warning
340 Invalid Last Principal Payment date; "Origination Date" used. Warning
341 Invalid Last Principal Payment date; Last Interest Payment Date used for conventional amortization types Warning
342 Invalid next principal payment date; "Origination date + 1" or "As-of-date + 1" used Warning
343 Invalid Next Principal Payment date; Next Interest Payment Date used for conventional amortization types Warning
344 Invalid original principal payment date; "Origination date + Interest Payment frequency" used. Warning
345 Invalid Original Principal Payment date; Original Interest Payment Date used for conventional amortization types Warning
346 Invalid value for principal payment frequency; Number of months between Origination and maturity date used; Warning
347 Invalid value for principal payment frequency; Interest Payment Frequency used for conventional amortization types Warning
348 Invalid value for interest payment frequency multiplier; Months (M) used; Warning
349 Invalid value for interest payment frequency multiplier; Interest Payment Frequency Multiplier used for conventional amortization types Warning
350 Invalid Account Type, Account type defaults to Earning Assets. Warning
351 Invalid record: Payment type and/or amount is mandatory Warning
352 Invalid record: Payment Date is mandatory Warning
353 Invalid record: Payment type is Principal and Interest but Total Amount (TOT_AMOUNT) is missing Error
354 Invalid record: Payment type is Principal Only but Principal Payment Amount (PRIN_AMOUNT) is missing Error
355 Invalid record: Payment type is Interest Only but Interest Payment Amount (INT_AMOUNT) is missing. Error
356 Invalid payment pattern: Payment Pattern Sub Type is not given Error
357 Invalid payment pattern: Payment Pattern Payment Type is not given Error
358 Invalid payment pattern: Payment event id is not given Error
359 Invalid payment pattern: Pattern type or sub type is Relative but frequency multiplier is not given Error
360 Invalid payment pattern: Pattern type is Absolute but event month is not given Warning
361 Invalid payment pattern: Pattern payment method is not given Error
362 Invalid payment pattern: Payment Pattern Type is not given Error
363 Invalid payment type code in payment pattern: Payment Type 300 (interest only) used; Error
364 Invalid payment pattern: Pattern type or sub type is Relative but frequency is not given Error
365 Invalid payment pattern: Pattern type is Absolute but event day is not given Error
366 Invalid payment pattern: Pattern type is Split but split id is not given Warning
367 Invalid payment pattern: Pattern type is Split but percentage of split is not given Error
368 Invalid payment pattern: Pattern type or sub type is Relative but payment event repeat is not given Error
369 Invalid payment pattern: Pattern Events not given Error
370 Invalid value for holiday calculation option; processed as Shift Dates. Error
371 Holiday Calculation Option can only be Recalculate when accrual basis is B/252 Error
372 Invalid value for holiday calendar code; Holiday adjustment not applied or details from process level parameters used; Error
373 Holiday Calendar Code is mandatory when accrual basis is B/252. Holiday details from process level parameters or A/A used. Warning
374 Invalid value for holiday rolling convention; Holiday adjustment not applied; Warning
375 Holiday Rolling Convention Code is mandatory when accrual basis is B/252. Following business day used. Warning
376 Reprice frequency is > 0 and calculation date range is last reprice to next reprice date but balance on last reprice date is not available; Processed using End of Period Principal Balance; Warning
377 Invalid value for margin type code; Default value RATE (0) used; Warning
378 Invalid value for net margin code; Default value NRSG (0) used; Warning
379 Invalid value for next reprice date; Default value Origination date + 1 or As-of-date + 1 used; Warning
380 Invalid value for last reprice date; Default value Next Reprice Date minus Reprice Frequency used; Warning
381 Warning: Negative Amortization Equalization Frequency cannot be negative; 0 used. Warning
382 Warning: Invalid Negative Amortization Equalization Frequency Multiplier; Months used. Warning
383 Warning: Negative Amortization Payment Change Frequency cannot be negative; 0 used. Warning
384 Warning: Invalid Negative Amortization Payment Change Frequency Multiplier; Months used. Warning
385 Warning: Negative Amortization Limit value does not fall in a valid range 0-200; 0 used. Warning
386 Warning: Negative Amortization Equalization date is less than origination date (future origination) or less than the as-of-date (past origination); Next Reprice Date used. Warning
387 Warning: Negative Amortization Equalization date is less than origination date (future origination) or less than the as-of-date (past origination); Next Reprice Date used. Warning
388 Warning: Negative Amortization Payment Adjustment date is less than origination date (future origination) or less than the as-of-date (past origination); Next Reprice Date used. Warning
389 Warning: Negative Amortization Payment Adjustment date is less than origination date (future origination) or less than the as-of-date (past origination); Next Reprice Date used. Warning
390 Warning: Negative Amortization payment change limit cannot be negative; Limit not applied. Warning
391 Maturity date of account is different from highest payment date in schedule; Dates from schedule used; Warning
392 Remaining Number of Payments given with account is different from count of payment dates after as of date in schedule; Dates from schedule used; Warning
393 Invalid value for next reprice date for a teaser instrument; Value derived by rolling forward Teaser End Date with Repricing Frequency; Warning
394 Invalid record: Maturity date is prior to As of date; Account not processed; Warning
395 Invalid record: Maturity date is prior to Origination date; Account not processed; Warning
396 Invalid record: Payment dates in schedule are prior to As of date; Account not processed; Warning
397 Principal balance is not zero but maturity date is prior to as of date; Maturity date defaulted to As of date + 1 Warning
398 Principal balance is not zero but maturity date is prior to origination date; Maturity date defaulted to As of date + 1 Warning
399 Next reprice date is after maturity date; Defaulted to maturity date; Warning
400 Invalid value for last reprice date; Default value Origination Date used; Warning
401 Invalid value for Adjustable Type; Calculation date range is AOD to NRD or LRD to NRD but adjustable Type of account is Fixed. Account not processed. Warning
402 Adjustable Type of account is Floating or Other Adjustable but repricing frequency multiplier is not given or is not valid; Months (M) used; Warning
403 Adjustable Type of account is Floating or Other Adjustable but Interest Rate Code is not given or is not valid; Processed with Interest Rate Code 0. Warning
404 Adjustable Type of account is Floating or Other Adjustable but repricing frequency is not given or is not valid; Processed with fixed interest rate. Warning
405 Adjustable Type of account is repricing pattern but repricing pattern code is not given or is not valid; Processed with fixed interest rate. Warning
406 Interest timing type not given; Interest In Arrears used; Warning
407 Interest timing type cannot be advance when amortization is conventional type; Interest In Arrears used; Warning
408 Amortization Type of account is payment pattern but pattern code is not given or is not valid; Processed as non-amortizing instrument. Warning
409 Accrual basis is B/252 but holiday adjustment is not enabled. A/A used. Warning
410 Amortization Type of account is payment schedule but schedule data is not given; Processed as non-amortizing account. Warning
411 Invalid value for next reprice date for a teaser instrument; Value derived by rolling forward Teaser End Date with Repricing Frequency; Warning
412 Invalid value for last reprice date for a teaser instrument; Value derived by rolling forward Teaser End Date with Repricing Frequency; Warning
413 Teaser End Date is after Maturity Date; Value defaulted to Maturity Date; Warning
414 Teaser End Date is before Origination Date; Value defaulted to Origination Date; Warning
415 Invalid Mortgage Offset Account Expected Balance as Expected Balance (MOA_EXPECTED_BAL) is empty or <= 0, Processed as normal instrument. Warning
416 Invalid Mortgage Offset Account Expected Balance Growth Percentage (MOA_EXPECTED_BAL_GROWTH_PCT), Processed with default value of 0. Warning
417 Invalid Mortgage Offset Account Expected Balance on last reprice date (MOA_LRD_OFFSET_BAL), Processed using default value as MOA_EXPECTED_BAL Warning
418 Invalid Mortgage Offset Account Minimum Balance (MOA_MIN_BAL), Processed with default value of 0. Warning
419 Invalid Mortgage Offset Percent (MOA_OFFSET_PERCENT), Processed with default value of 100 Warning
420 Invalid Mortgage Offset Account Original Expected Balance (MOA_ORG_OFFSET_BAL),but since calculation date range is Origination to Maturity, Processed as normal instrument. Warning
421 Invalid Mortgage Offset Account Original Expected Balance (MOA_ORG_OFFSET_BAL). but since calculation date range is other than Origination to Maturity, Process account with considering the mortgage offset account as Original Expected Balance doesnt impact on MOA calculations. Warning
422 One or more required inputs are missing for factors calculation using arc tangent method Warning
423 Cannot generate prepayment factors dates if PaymentDates are not provided Warning
424 Cannot generate early redemption dates if PaymentDates are not provided Warning
425 user tenor rules are not defined in prepayment meta data Warning
426 conditions are not satisfied to apply early redemption on user defined tenors Warning
427 Cannot generate prepayment factors dates if PaymentDates are not provided; Warning
428 Behavior pattern is not applicable when calculation data range is Origination to Maturity. Generated cash flows from As of date to maturity Warning
429 Behavior pattern is not applicable when calculation data range is Last Reprice to Next Reprice Date. Generated cash flows from As of date to Next Reprice Date Warning
430 Maturity Date < Max Date of Pattern, Maturity Date set to Max Tenor of behavior pattern Warning
431 Invalid value for Behavior Sub Type of account having devolvement & recovery or non-performing behavior type; Account not processed; Error
432 Invalid value for devolvement status of account; Account not processed; Error
433 Devolvement amount cannot be negative when devolvement status of account is devolved; Default value of 0 used; Error
434 Invalid value for Behavior Type of account; Processed using behavior type from pattern definition. Warning
435 Invalid behavior pattern: Behavior Type is not given or is incorrect; Behavior pattern not used; Processed as non-amortizing instrument; Warning
436 Invalid behavior pattern: Behavior Sub Type is not given or is incorrect; Behavior pattern not used; Processed as non-amortizing instrument; Warning
437 Invalid behavior pattern: Tenor multiplier is not given; Processed as non-amortizing instrument; Error
438 Invalid behavior pattern: Tenor is not given; Processed as non-amortizing instrument; Error
439 Invalid behavior pattern: Percentage is not given; Processed as non-amortizing instrument; Error
440 Invalid behavior pattern: Sequence is not given; Processed as non-amortizing instrument; Error
441 Behavior Type definition is inconsistent between the Behavior Pattern and BEHAVIOR_TYPE_CD of account. Defaulted to the Behavior Type specified in the Behavior Pattern. Warning
442 Interest in advance is not supported for behavior patterns, defaulting to Interest in Arrears Warning
443 No prepayment parameter is found for payment date Warning
444 Cannot generate early redemption prepayment rates if payment dates are not provided or calculation method is not Constant Warning
445 Invalid value for Exchange of Principal flag for Off-balance sheet product; Processed with No Exchange of Principal Warning
446 Invalid value for Exchange of Principal flag for Off-balance sheet product; Processed with Leg Type 0 Warning
447 Invalid value for Minimum Balance for Amortizing Swap; Processed with value 0 Warning
448 Invalid value for purchase sale logic of Off-balance sheet product; Processed as sold contract (1) Warning
449 Invalid value for swap classification code; Processed as generic swap (0) Warning
450 Invalid Last Reprice Date for Forward Rate Agreement; Processed using Origination Date Warning
451 Invalid Repricing Frequency Multiplier for Forward Rate Agreement; Processed using Original Term Multiplier Warning
452 Invalid Next Reprice Date for Forward Rate Agreement; Processed using Origination Date; Warning
453 Invalid Repricing Frequency for Forward Rate Agreement; Processed using Original Term; Warning
454 Invalid Exchange of Principal flag for Forward Rate Agreement; Processed using No Exchange of Principal Warning
455 Invalid Interest Timing Type for Forward Rate Agreement; Processed as Interest in advance Warning
456 Invalid Adjustable Type for Forward Rate Agreement; Processed as Other Adjustable (250); Warning
457 Invalid Origination Date for Forward Rate Agreement; Processed with value As of Date + 1; Warning
458 Invalid Maturity Date for Forward Rate Agreement; Processed using Origination Date + Original Term; Warning
459 Invalid Remaining Number of Payments for Forward Rate Agreement; Processed using 1 Warning
460 Invalid Next Interest Payment Date for Forward Rate Agreement; Processed using Origination Date Warning
461 Invalid Next Principal Payment Date for Forward Rate Agreement; Processed using Origination Date Warning
462 Invalid Original Interest Payment Date for Forward Rate Agreement; Processed using Origination Date Warning
463 Invalid Original Principal Payment Date for Forward Rate Agreement; Processed using Origination Date Warning
464 Invalid Last Interest Payment Date for Forward Rate Agreement; Processed using Origination Date; Warning
465 Invalid Interest Payment Frequency for Forward Rate Agreement; Processed using Original Term Warning
466 Invalid Interest Payment Frequency Multiplier for Forward Rate Agreement; Processed using Original Term Multiplier Warning
467 Invalid Principal Payment Frequency for Forward Rate Agreement; Processed using Original Term Warning
468 Invalid Principal Payment Frequency Multiplier for Forward Rate Agreement; Processed using Original Term Multiplier Warning
469 Invalid Amortization Type for Forward Rate Agreement; Processed as non-amortizing (700) instrument; Warning
470 Invalid value for Exchange of Principal flag for Foreign Exchange instrument; Processed with Exchange of Principal; Warning
471 Invalid Amortization Type for Foreign Exchange instrument; Processed as non-amortizing (700) instrument; Warning
472 Invalid Adjustable Type for Foreign Exchange instrument; Processed as Fixed; Warning
473 Invalid Interest Timing Type for Foreign Exchange instrument; Processed as Interest in arrears; Warning
474 Invalid current gross interest rate for Foreign Exchange instrument; Processed with no interest; Warning
475 Invalid current net interest rate for Foreign Exchange instrument; Processed with no interest; Warning
476 Invalid remaining number of payments for Foreign Exchange Contract; Processed with 1 remaining payment; Warning
477 Invalid Next Interest Payment Date for Foreign exchange contract; Processed using Maturity Date; Warning
478 Invalid Next Principal Payment Date for Foreign exchange contract; Processed using Maturity Date; Warning
479 Invalid Original Interest Payment Date for Foreign exchange contract; Processed using Maturity Date; Warning
480 Invalid Original Principal Payment Date for Foreign exchange contract; Processed using Maturity Date; Warning
481 Invalid Next Reprice Date for Foreign exchange contract; Processed using Maturity Date; Warning
482 Invalid Repricing Frequency for Foreign Exchange Contract; Processed using Original Term; Warning
483 Invalid Repricing Frequency Multiplier for Foreign Exchange Contract; Processed using Original Term Multiplier; Warning
484 Invalid Interest Payment Frequency for Foreign Exchange Contract; Processed using Original Term; Warning
485 Invalid Interest Payment Frequency Multiplier for Foreign Exchange Contract; Processed using Original Term Multiplier; Warning
486 Invalid Principal Payment Frequency for Foreign Exchange Contract; Processed using Original Term; Warning
487 Invalid Principal Payment Frequency Multiplier for Foreign Exchange Contract; Processed using Original Term Multiplier; Warning
488 Invalid Last Interest Payment Date for Foreign Exchange Contract; Processed using Origination Date; Warning
489 Invalid Last Reprice Date for Foreign Exchange Contract; Processed using Origination Date; Warning
490 Invalid End of Period Principal Balance for Foreign Exchange Swap; Processed using no balance; Warning
491 Invalid Original Principal Balance for Foreign Exchange Swap; Processed using no balance; Warning
492 Invalid value for next reprice date for a teaser instrument; Defaulted to Teaser End Date; Warning
493 Repricing pattern can not be used for teaser instrument; Warning
494 Interest timing type cannot be advance when conventional payment pattern is used, Interest In Arrears used as default; Warning
495 Interest timing type cannot be advance when Account Type is Other Asset or Other Liabilities or Non-Interest Income or Non-Interest Expense or Interest Income or Interest Expense, Interest In Arrears used as default; Warning
496 Last interest payment date cannot be before Origination Date; Default value Origination Date used; Warning
497 Last principal payment date cannot be before Origination Date; Default value Origination Date used; Warning
498 Invalid amortization type for Other Asset-Liability; Processed as Non-amortizing instrument; Warning
499 Invalid current net interest rate for Other Asset-Liability; Processed without interest and default as 0; Warning
500 Invalid current gross interest rate for Other Asset-Liability; Processed without interest and default as 0; Warning
501 Invalid adjustable type for Other Asset-Liability; Processed as fixed rate; Warning
502 Interest timing type cannot be advance when adjustable type is floating rate, Interest In Arrears used as default; Warning
503 Repricing pattern code is empty; Warning
504 Adjustable Type of account is Repricing Pattern but Repricing Pattern definition not given. Processed as Other Adjustable (250); Warning
505 Repricing Pattern Type Code is invalid in repricing pattern definition. Account not processed; Error
506 Repricing Pattern Events UDS is empty Error
507 Event Sequence number is invalid in repricing pattern definition. Account not processed; Error
508 Repricing Method Code is invalid in repricing pattern definition. Account not processed; Error
509 Balance Tier Type Code is invalid in repricing pattern definition. Account not processed; Error
510 Event Day is invalid in absolute repricing pattern definition. Account not processed; Error
511 Event Month is invalid in absolute repricing pattern definition. Account not processed; Error
512 Repricing Pattern EventsDetail UDS is empty Error
513 Event Detail Sequence number is invalid in repricing pattern definition. Account not processed; Error
514 Repricing method is Indexed but Interest Rate Code is not given in repricing pattern definition. Account not processed; Warning
515 Event Frequency is invalid in relative repricing pattern definition. Value assumed to be 1 Month; Warning
516 Event Frequency Multiplier is invalid in relative repricing pattern definition. Value assumed to be 1 Month; Warning
517 Event Repeat Times is invalid in relative repricing pattern definition. Value assumed to be 1; Warning
518 Adjustable type code of account is 300 but corresponding data of balance tiers and rate is not available; Processed with fixed interest rate; Warning
519 Invalid amortization type for an account with Balance Tier Interest Rate; Processed as non-amortization instrument; Warning
520 Adjustable type of tier cannot be Floating Rate if Interest Timing Type of account is Advance; Processed as Interest in Arrears; Warning
521 Adjustable type code of account is 300 but corresponding adjustable type of balance tiers is invalid; Processed tier with fixed interest rate; Warning
522 Adjustable type code of balance tier is 250 but next reprice date, last reprice date or reprice frequency are missing; Processed tier with fixed interest rate; Warning
523 Sum of current balances of all tiers of account is different from current par balance of account; Warning
524 Current balance of tiers of account is not given; Account not processed; Error
525 Sum of original par balances of all tiers of account is different from original par balance of account; Warning
526 Original par balance of tier not given; End of Period Principal Balance used; Warning
527 Invalid Contract Currency Pay for Foreign Exchange Swap; Warning
528 Invalid Original Payment Amount Pay for Foreign Exchange Swap; Warning
529 Invalid Contract Currency Receive for Foreign Exchange Swap; Warning
530 Invalid Original Payment Amount Receive for Foreign Exchange Swap; Warning
531 Invalid Exchange Rate Start for Foreign Exchange Swap; Warning
532 Invalid Receive CCY for Foreign Exchange Swap; Warning
533 Invalid Receive Leg Amount for Foreign Exchange Swap; Warning
534 Invalid Pay CCY for Foreign Exchange Swap; Warning
535 Invalid Pay Leg Amount for Foreign Exchange Swap; Warning
536 Invalid Exchange Rate End for Foreign Exchange Swap; Warning
537 Interest timing type cannot be advance when interest is capitalized; Interest In Arrears used; Warning
538 Amortization type of Interest Rate Option can only be Non amortizing (700) or Level principal (820); Processed as Non amortizing instrument; Warning
539 Binary Rate of Interest Rate Option cannot be less than zero; Processed without binary rate; Warning
540 Invalid Interest Calculation Type for Interest Rate Option; Processed with default calculation type; Warning
541 Functionality not implemented for Interest Calculation Types Numeric Average, Geometric Average, Range Calculation and Binary Range; Processed with default calculation type; Warning
542 Adjustable Type of Interest Rate Option can only be Other Adjustable (250); Warning
543 Next Reprice Date of Interest Rate Option must be same as Next Interest Payment Date; Warning
544 Last Reprice Date of Interest Rate Option must be same as Last Interest Payment Date; Warning
545 Reprice frequency of Interest Rate Option must be same as Interest Payment Frequency; Warning
546 Reprice Frequency Multiplier of Interest Rate Option must be same as Interest Payment Frequency Multiplier; Warning
547 Adjustable type code for of 78s instrument can only be fixed rate; Warning
548 Interest Timing Type of of 78s instrument can only Interest in Arrears; Warning
549 Interest payment frequency of of 78s instrument must be 1 month; Warning
550 Interest payment frequency multiplier of of 78s instrument must be in Months; Warning
551 Principal payment frequency of of 78s instrument must be 1 month; Warning
552 Principal payment frequency multiplier of of 78s instrument must be in Months; Warning
553 Last Interest and Principal payment date of of 78s instrument must be same; Set Last Principal Payment Date = Last Interest Payment Date Warning
554 Next Interest and Principal payment date of of 78s instrument must be same; Set Next Principal Payment Date = Next Interest Payment Date Warning
555 Original Interest and Principal payment date of of 78s instrument must be same; Set Original Principal Payment Date = Original Interest Payment Date Warning
556 Original Principal Balance of of 78s instrument must be higher than End of Period Principal Balance; Warning
557 Original Term Multiplier of of 78s instrument must be in months; Warning
558 Original Term of of 78s instrument must be in months; Number of months between Origination and maturity date used; Warning
559 Current Payment Amount of of 78s instrument must not be zero; Warning
560 Original Payment Amount of of 78s instrument must not be zero; Warning
561 Remaining Number of Payments is different from number of months between Last Interest Payment Date and Maturity Date; Cash flows may have error; Warning
562 Interest timing type can be Set in Arrears only when calculation date range is As of date to Maturity; Interest In Arrears used; Warning
563 Amortization type of instrument can only be Simple Interest when embedded option is applied; Processed as non-amortizing instrument with embedded option; Warning
564 Invalid Option Exercise Type; Processed as instrument without embedded option; Warning
565 Option start date is required for American options, As of date used; Warning
566 Invalid Option Type; Processed as instrument without embedded option; Warning
567 Invalid Option Strike Type Code; Processed as instrument without embedded option; Warning
568 Invalid Option Rate Lookup Code, Remaining Term used; Warning
569 Rate lookup code for fixed rate instrument cannot be reprice frequency, Remaining Term used; Warning
570 Invalid Option Strike Interest Rate Code; Processed as instrument without embedded option; Warning
571 Option expiry date must be between As-of-date and Maturity date, Processed using Maturity Date as Expiry Date; Warning
572 Option Strike Value not given for embedded option, Strike price 100 used; Warning
573 Option Strike Value not given for embedded option, Strike rate set same as current net interest rate; Warning
574 Embedded options schedule not given for Bermudan option, Processed as instrument without embedded option; Warning
575 Option expiry date not given for Bermudan option in schedule; Processed as instrument without embedded option; Warning
576 Option expiry date must not be after Maturity date, Processed using Maturity Date as Expiry Date; Warning
577 Option Strike Value not given for embedded option, Strike price 100 used; Warning
578 Option Strike Value not given for embedded option, Strike rate set same as current net interest rate; Warning
579 Either Embedded Option Flag is Not Y or Invalid Option decision type, where instrument is Earning Asset or Interest Bearing Liabilities; Warning
580 Invalid Index Adjustment Type. Processed without inflation-adjustment; Warning
581 Account Index History not been given for inflation adjusted instrument. Processed without inflation-adjustment; Error
582 Base Index Value not been given for inflation adjusted instrument. Processed without inflation-adjustment; Error
583 Invalid Capital Protection Category for inflation indexed instrument. Processed with floor of 1; Warning
584 Capital Protection Category for inflation indexed instrument is Max during life but Max Index Value is invalid; Processed with Capital Protection Category as Floor or 1; Warning
585 Invalid Option decision type, where Embedded Option Flag is enabled, Processed as instrument without embedded option; Warning
586 Invalid Account Type, for embedded option, Processed as instrument without embedded option Warning
587 Invalid DiscountMethod Sys Id, for embedded option, Processed as instrument without embedded option; Warning
588 Invalid value for Amortization Method for Premiums and Discounts; Level Yield method used Warning
589 Batch size is empty Warning
590 Request ID is empty Warning
591 Invalid Interest rate code Warning
