2.4.2 Using Scheduler Service
To execute the cash flow process, follow these steps:
- Navigate to Operations and Processes menu, and select Scheduler.
- Define a new batch.
- Enter the Batch Name and Description, and then Save the batch.
- To add a task, navigate to Define Task.
- Select the Batch from Batch drop-down list on Define Task window.
- Click the Add button.
- Define the Task Code, Task Name, and Description.
- Select Components as “Cash Flow Process”.
- Input the following mandatory parameters:
- Process Name
- Legal Entity Hierarchy
- Legal Entity
- Save and Execute the batch with Batch ID and MIS Date.
For more information, see the Scheduler Service.
