6.1 Overview of Cash Flow Report
The Cash Flow Report UI allows you to view the reports with the following information:
  1. View the report for following input information about the selected instrument as follows:
    • Instrument Attributes
    • Payment Schedule, if applicable
    • Rate Tiers, if applicable
    • Embedded Options Schedule, if applicable
    • Index History, if applicable
  2. View the report for the following output information about the selected instrument as follows:
    • Cash Flow
    • Forecast Interest Rate Curve, if applicable
    • Forecast Economic Indicator, if applicable
    • Messages logged during processing
The Cash Flow Report Summary Page allows you to do the following:
The account number based on the search criteria are listed here. This is the search section that contains multiple parameters. You can specify one or multiple search criteria in this section. It is mandatory to select a Process and Execution ID to view the report. When you click Search, depending upon the search criteria, this filters and displays the relevant search combination parameters under the Cash Flow Report Summary as a list. You can perform search on the following search criteria:
  • As of Date
  • Process Name
  • Execution ID
  • Legal Entity
  • Products
  • Currency
  • Account Number
The Cash Flow Report Summary Page displays the following columns:
Table 6-1 Cash Flow Process rule – Fields and Descriptions
Column Description
Account Number Displays the Account Number of Cash Flow Report
As of Date Displays the As of Date of the Instrument
Legal Entity Displays the Legal Entity of the Instrument
Product Displays the Product
Currency Displays the Currency of the Instrument
