3.15.5 Copy Discount Method Rule
You can copy Discount Method Rules to avoid having to enter data multiple times. This saves time and effort and also reduces mistakes.
To copy a Discount Method Rule, follow these steps:
- Navigate to the Assumption and select Discount Method.
- Search for a Rule.
For more information, see the Searching for Rules section.
- Click on the Action icon against the Discount Method Rule Name and select Save As to duplicate the rule.
- Select a folder where you want to save the rule copy.
- Enter a unique name for the new rule.
- (Optional) Enter a brief description of the rule.
- Select the access type.
- Click the Save button.
