4.2.3.6 Downloading Dump File
You can download the export dump file for exported definitions to a local directory, using Download Dump file option.
The downloaded export dump file can be used to upload objects to a different environment.
This option is enabled, only if the definition is exported successfully and the Migration Status is set to Success.
To download a export dump file, refer to the following procedure.
  1. Mouseover a migrated object and select Menu.
  2. Select Download Dump File from the drop-down menu, to download the associated dump file and store it to the local directory.
