3.16.1 Filter Definition Types
Filter definitions are created based on the different object types.
The following filter definition types are supported:
  • Attribute Filter - filters based on one or more Dimension Type Attributes. For each attribute, you can select one or more values.
  • Data element filter -filters the columns based on specific data constraint. These filters are used within other rule types such as Allocation Rules, Transfer Pricing Rules, Asset and Liability Management Rules.
  • Group filter - combined filter containing multiple Data element filters logically connected using the AND operator.
  • Hierarchy filter - filters using Rollup Nodes within a Hierarchy and exclude or include data within an OFSAA Rule.
