5.1.3.8.4 Off Balance Sheet Transaction Summary
The Off Balance Sheet Transaction Summary Report provides the analysis capability on the Off Balance Sheet Transaction Summary Table.
You can use a series of Report Prompts to filter the data according to Functional Key Attributes pertaining to the Table Columns Perimeter.
The report displays the underlying data according to the following Charts’ logic:
  • Off Balance Sheet Transaction Summary - Number of Records Trend
    Total Record Off Balance Sheet Transaction Summary aggregated by AS_OF_DATE.
    Granular table records at ID_NUMBER level.
Figure 5-53 Processing Transaction Summary Data – Off Balance Sheet Transaction Summary
