4.3.1.7 Dependency Check
You can check dependencies for rules to know where a particular Prepayment Rule has been used. This also prevents accidental deletion of rules having dependencies.
To check the dependency of a rule, follow these steps:
- Navigate to the Assumption and select Prepayment Rule.
- Search for a rule. For further information, see the Search Prepayment Rules section.
- Click on the Action icon against the Prepayment Rule Name and select Dependency Check to the rule that you want to check for.
This is functionality will be released in future.
