2.3.3.4 Folders Summary Page
You can create multiple Folders, store objects and assign access rights based on the security level of the user.
The Folders Summary page shows the list of available groups. You can view the details of a group and map the group to one or more user Roles.
To access Folders Summary page, complete the following steps:
  • Click Identity Management tab in the Admin Console page.
  • Click the Folders tile, to access the Folders Summary page.
    The Folders Summary page is displayed.
Figure 2-54 Folders Summary Page
Select a specific Folder Name in the Folders Summary page and then click Details to view the associated Folder ID, Folder Name and Folder Type. For more information refer to Folder Details.
To search for a specific user group, type the first few letters of the user group name that you want to search in the search box and click Search. The search results display the names that consist of your search string in the list of available users.
At the bottom of the page, you can enter the number of entries that are available on a single page in the Records box. You can increase or decrease the number of entries that are displayed using the up and down arrows. To navigate between pages in the View bar, use the following buttons:
  • Use the First page first_page button to view the entries in the first page.
  • Use the Previous page previous_page button to view the entries in the previous page.
  • Use the Next page next_page button to view the entries in the next page.
  • Use the Last page last_page button to view the entries in the last page.
You can also navigate to the desired page. To do this, enter the page number in the View bar control and press Enter.
