4.1.2.1 Searching for Interest Rate Curve
There are two Search panes provided to search for Interest Rate Curves, which are explained.
To search the Interest Rate, perform the following steps:
- Click the Search icon on the Search Pane to collapse (display) the Search Criteria Window.
- Enter the Search Criteria by entering one or more of the Interest Rate Code, Name, Currency, Rate Format, and Structure Type.
- Click Reset to remove the filter criteria on the Search Window and refresh the window.
- Click Search after entering the search
criteria.
The search results are displayed in a Table containing all the Interest Rate Curves that meet the Search Criteria with the following details:
- Interest Rate Code: Displays the Interest Rate Curve's Code. The code is a unique number in the range of 1 to 9999999. Hover on a row in the pane to display the Interest Rate Curve's detailed description.
- Name: Displays the Interest Rate Curve's short name.
- Structure Type: Displays the Structure Type (Standard, Hybrid) of the Interest Rate Curve.
- Currency: Displays the Currency (Reference Currency) for which Interest rate curve is defined.
- Created By: Displays the Name of the user who created the Interest Rate Curve.
- Creation Date: Displays the Date and Time when Interest Rate Curve was created.
- Last Modified By: Displays the Name of the user who last modified the Interest Rate Curve.
- Last Modified Date: Displays the Date and Time when Interest Rate Curve was last modified.
- Click on the Action icon against the Interest Rate Code to do further actions View, Edit, Delete, and Save As on the selected Interest Rate Code.
The Interest Rate Curve Summary Page offers several icons that allow you to perform different functions when an Interest Rate Curve is selected.
The other method to search an Interest Rate Code or Codes is using the Field Search Pane. You can enter any one of the details of an Interest Rate curve, displayed on summary UI and press the Enter key to display list of filtered Interest Rate Curves.
The top bar displays the Title of the screen and the following icons:
- Add: This allows you to add a new Interest Rate Code.
- Delete: This allows you select one or multiple Interest Rate Codes from the Summary Table and delete them.
- Refresh: Clears the search criteria definitions and refreshes the Screen.
- Help: Opens the help page of the Interest Rate Curves Screen.
