4.3.2.4 View and Edit Prepayment Model Rule
You can view existing Prepayment Model, and you can edit existing Prepayment Model Rules, provided you have Read/Write privileges.
To view and edit a Prepayment Model, follow these steps:
  1. Navigate to the Assumption and select Prepayment Model.
  2. Search for a Rule. For further information, see the Searching for Rules section.
  3. Click on the Action icon against the Prepayment Model Rule Name and select View/Edit to open the Rule you want to update.
  4. Update the Rule details.
  5. Click Apply or Save, depending on the Rule Type.
