7.1.4.1.4 GL Account
The following Report Filters are available:
- GL Account Hierarchy Name: Note that this is a mandatory
filter for the group filtering on GL Account Key Processing Dimension.
As the Application supports the creation of multiple hierarchies for the same Dimension of analysis, and to avoid displaying results from multiple Dimension Hierarchies at the same time, a mandatory driver to select “GL Account Hierarchy Name” must be selected with only a single value simultaneously.
- GL Account Leaf Name: You can use this filter to select the GL Account Leaf Name that is related to the underlying Management Ledger data.
Figure 7-58 GL Account - Key and Standard Dimensions Registry
