6.2.2.2.1.1 Define Absolute Payment Patterns
Absolute payment patterns are commonly used for instruments that are on a seasonal schedule, such as agricultural or construction loans that require special payment handling based on months or seasons.
When working with absolute payment patterns, it is sufficient to define payments for one calendar year. Once the term exceeds a year, the payment schedule will loop until the instrument matures.
Prerequisites
Selecting Absolute as the pattern type.
Figure 6-32 Absolute Payment Patterns
To define absolute payment pattern, do the following:
  1. In the Payment Patterns page, select Pattern Type as Absolute.
  2. Select the Payment Type from the drop-down list: Conventional, Level Principal, or Non-Amortizing. The Payment Type determines the type of information required to successfully define the Payment Phase.
  3. Define the Payment Phases. A Payment Phase is a set of payment characteristics that defines the timeline of the instrument's amortization.
    1. Define the following parameters:
      • Month: This drop-down list allows you to select the month of the payment phase being defined.
      • Day: Used to specify the day of the month the payment is due.
    2. Select the Cash Flow Type. The available types depends on the Payment Type. This do not apply to the Non-Amortizing Payment Type.
      Table: Relationship between Cash Flow Type and Payment Types
      Level Principal Non-Amortizing Conventional
      Principal and Interest Yes Yes
      Principal Only Yes
      Interest Only Yes Yes
    3. Select the Payment Method. The available Payment Methods depend on the Payment Type. For more information, see: Relation between Payment Method and Payment Types. Payment Methods do not apply to the Non-Amortizing Payment Type.
    4. Enter the Value for the Payment Method you selected in the previous step for applicable Payment Types.
      If you selected the Interest Only Payment Method in the previous step, the Value field does not apply.
  4. Click the Add icon to add additional Payment Phases to the Pattern. Click Delete icon corresponding to the rows you want to delete.
  5. Click Add Multiple Row icon to enter the number of rows you want to add and click Go.
  6. The Download Excel icon helps you to export payment information, modify and paste back in the UI.
    A Payment Pattern must have at least one valid Payment Phase to be successfully defined. The system raises a warning if you try to save a Payment Pattern with an incomplete Payment Phase.
  7. Click Apply and Save.
The Payment Pattern is saved and the Payment Pattern summary page is displayed.
The following table describes the relationship between Payment Phase properties and Payment Types.
Relationship between Payment Phase Properties and Payment Types
Month Yes Yes Yes
Day Yes Yes Yes
Payment Method Yes Yes
Value Yes Yes
The following table describes the relationship between Payment Method and Payment Types.
Relationship between Payment Methods and Payment Types
Payment Method Level Principal Non-Amortizing Conventional
Percentage of Original Balance Yes
Percentage of Current Balance Yes
Percentage of Original Payment Yes Yes
Percentage of Current Payment Yes Yes
Absolute Payment Yes Yes
