Data Export Downloader Utility
Public API to retrieve the manifest file. This feature allows the automation of file download process. The API returns a manifest file in JSON format. Manifest includes file details and URLs for downloading. This reduces the manual download steps.
This utility uses configuration from a `.env` file and securely fetches export files from Oracle Object Storage using token-based authentication. For more information, refer to Data Export Download document on My Oracle Support.
- Retrieve the manifest fileInvoke the REST service below to obtain the
manifest file
details:
/dataextractor/getDataExportManifestFile?code=<export_definition_code>&batchRunId=<batch_run_id> - Enter Export Definition Code and Batch Run ID.
You can retrieve the data using export definition code and batch run ID. The Code value shown as a tooltip in Data Export UI (move-over Name field on Data Export Summary UI). Batch run ID visible in the Export Details UI. Also, these details are available in LogViewer Service UI.It will download the JSON . Below is an example:
Example request:
/dataextractor/getDataExportManifestFile?code=987654321&batchRunId=DATA_EXTRACTION_RUN1Sample response:
"payload": {
"executedBy": "caqa_user",
"batchRunId": "Data_Extraction_111111_2022-04-26_2",
"fileDetails": [
"fileName": xyz.gz,
"fileSize": "247"
"dateFormat": "MM-dd-yyyy HH:mm:ss UTC",
"executedOn": "11-18-2025 06:31:14",
"rowsLoaded": "4916",
"exportFilePrefix": "Data_Extraction_111111_2022-04-26_2/Task1",
"parUrlExpiryTime": "12-13-2025 13:28:05",
"statusName": "Success",
"asOfDate": "04-26-2022",
"endTimestamp": "11-18-2025 06:31:16",
"taskId": "Task1",
"startTimestamp": "11-18-2025 06:31:14",
"statusCode": "SUCCESS"
"status": "Success"
- Parse the response
Parse the JSON response to extract the “fileName” attribute, which contains the PAR (Pre-Authenticated Request) URLs for the exported files.
- Download the files
Use the PAR URLs obtained from the manifest response to download the exported files directly.
