Audit Info Pane
The Audit Info pane is a standard footer pane available for every Profitability Management Cloud Service rule type. It displays the following tabs:
  • Audit: Shows audit data for the object, including Created By, Created Date, Modified By, Modified Date, Authorized By, and Authorized Date.
  • Comments: Shows existing comments for the object. Only the latest comment is editable; deletion of existing comments is not permitted. Users can add new comments.
  • Tags: Shows the tags associated with the object. Users can add new tags or remove existing ones.
