Behavior Patterns
PBSM (Profitability and Balance Sheet Management) Cloud Service’s User Defined Behavior Patterns allow you to define Principal Amortization Schedules for Non-Maturity Products in your portfolio. You can utilize a Behavior Pattern to generate Cash Flows by entering the Amortization Type Code as “Behavior Pattern” along with the actual Behavior Pattern Code for the relevant Instrument Records.
Behavior Pattern Summary
This page is the gateway to all Behavior Patterns and related functionality. You can navigate to other pages relating to Behavior Patterns from this point.
Figure 6-24 Behavior Pattern Summary
The Behavior Pattern Summary displays the following information:
Add: Click the Add on the page header to build a new Behavior Pattern rule.
Actions: Enables you to perform following tasks.
- Refresh: Retains the selected filters and refreshes the summary page with latest status.
- Reset: Clears the selected filters and refreshes the summary page.
- Help: Redirects you to latest documentation.
Delete: Enables you to select and delete one or multiple rules in the table simultaneously.
Pin/Unpin: Enables you to pin/unpin the selected rule.
Export: Enables you to download the summary page details in .CSV format.
Columns: Allows you to view the summary page data using a customized list of columns.
- Code: Numeric code of the Behavior Pattern
- Name: The Behavior Pattern's name.
- Behavior Type: The type of Behavior Pattern.
- Last Modified By: The user who last modified the Behavior Pattern.
- Last Modified Date: The Date and Time when the Behavior Pattern was last modified.
- Action: Click this icon to view a list of
actions that you can perform on the Behavior Pattern.
- View: You can view an existing Behavior Patterns.
- Edit: Based on the user privilege assigned, you can edit existing Behavior Patterns. To edit a rule, you must have Read/Write privilege.
- Save As: You can reuse a Behavior Pattern by saving it under a new name thus saving time and effort in entering data multiple times; it also leads to reduced data entry errors.
- Delete: You can delete Behavior Patterns that you no longer require. A Behavior Pattern that has a dependency cannot be deleted.
- Dependency Check: You can perform a dependency check
to know where a particular Behavior Pattern has been used. Before
deleting a rule, it is always a good practice to do a dependency check
to ensure you are not deleting Behavior Patterns that have dependencies.
A report of all rules that utilize the selected Behavior Pattern is
generated.
This is functionality will intended for a future release.
Search Behavior Pattern
Prerequisites: Predefined Behavior Pattern
To search for a Behavior Pattern:
Click Search after entering the search criteria. The search results are displayed in a table containing all the Behavior Patterns that meet the search criteria.
Also See:
