Common Feature Controls
PBSM Cloud Service includes many common feature controls.
Figure 3-33 Audit Info
Audit Info
Audit
The Audit Trail container is a standard footer container for every PBSM rule type. It displays Created By, Creation Date, Last Modified By, Modification Date, Authorized By, and Authorized Date on the Audit tab.
User Comments
The User Comments tab may be used to add comments to any rule, subject to a maximum of 4000 characters.
Tags
The Tags tab allows you to add a tag to the selected Rule ID.
