Create and Execute Batch
To create and execute the batch:
Before executing the ADS batch, ensure the following prerequisite is met:- If the PBSM tenant has undergone a G2 certification update, the updated PBSM wallet must be uploaded to DFCS prior to batch execution.
- If the wallet is not updated post-G2 certification, all ADS batch runs will fail regardless of data availability. Contact Oracle Support to complete the wallet upload.
- From the LHS menu, navigate to Operations and Processes, select Scheduler, and then select Define Batch. For more details, see Define Batch.
Task. For more details, see Adding a Task.
Refer to the following table for Component and Parameters to be defined for different tasks.
Table 5-9 Components and Parameters
Component Parameters Target Tables PBSM_DFCS_Data_Transfer_instruments ADS Id: This displays list of data connectors available. Select one value from LOV.
Data File Specification Id: This displays list of seeded and user defined DFS definitions. Select one relevant value for the selected ADS.
Data Source Id: This displays members of ‘Instrument Data Source’ dimension. Select one value from LOV. Instrument data belonging to this source only will be moved from DFCS to PBSM.
Optional Input: This can be used to specify any other input parameter in JSON Object/String.
Stage Assets
Stage Liabilities
Stage Derivatives
Stage Fee Based Services
Stage Loan Commitments
Stage Off Balance Sheet
PBSM_DFCS_Data_Transfer_Dimensions ADS Id: This displays list of data connectors available. Select one value from LOV.
Stage Dimensions Interface PBSM_DFCS_Data_Transfer_ExchangeRates ADS Id: This displays list of data connectors available. Select one value from LOV.
Rate Data Source Id: This displays members of ‘Rate Data Source’ dimension. Select one value from LOV. Data belonging to this source only will be moved from DFCS to PBSM.
Stage Exchange Rates PBSM_DFCS_Data_Transfer_InterestRates ADS Id: This displays list of data connectors available. Select one value from LOV.
Stage IRC Rate History PBSM_DFCS_Data_Transfer_InstrumentSupplementary ADS Id: This displays list of data connectors available. Select one value from LOV.
Stage Account Index History
Stage Account Rate Tiers
Stage Embedded Options Schedule
Stage Payment Schedule
Stage Interest Rate Schedule
PBSM_DFCS_Data_Transfer_Transaction_Summary
Data File Specification Id: This displays the list of DFS rules defined for a Staging table. Select one relevant value for the selected ADS.
Data Source Id: This displays members of ‘Transaction’ dimension. Select one value from LOV. Instrument data belonging to this source only will be moved from DFCS to PBSM.
Optional Input: This can be used to specify any other input parameter in JSON Object/ String.
Stage Asset Transaction
Stage Liability Transaction
Stage Fee Based Transaction
Stage Off Balance Sheet Transaction
PBSM_DFCS_Data_Transfer_Customer
Data Source Id: This displays members of ‘Customer’ dimension. Select one value from LOV. Instrument data belonging to this source only will be moved from DFCS to PBSM.
Stage Customer Hierarchy
Stage Customer Master
PBSM_DFCS_Data_Transfer_Management_Ledger
Stage Management Ledger PBSM_DFCS_Data_Transfer_EconomicInd ADS Id: This displays list of data connectors available. Select one value from LOV.
Rate Data Source Id: This displays members of ‘Transaction’ dimension. Select one value from LOV. Instrument data belonging to this source only will be moved from DFCS to PBSM.
Stage Economic Indicator Rate History
PBSM_DFCS_Data_Transfer_VolatilityRates ADS Id: This displays list of data connectors available. Select one value from LOV.
Stage IRC Volatility Rate History
PBSM_DFCS_Data_Transfer_VolatilitySurface ADS Id: This displays list of data connectors available. Select one value from LOV.
Stage Volatility Surface Rate History
- Select the seeded batch and click Edit Parameters. In the Dynamic Parameters pop-up window, change the date to the relevant As-of-Date, and then save the batch.
- From the LHS menu, navigate to Operations and Processes, select Scheduler, and then select Execute Batch. For more information, see Schedule Batch.
- From the LHS menu, navigate to Operations and Processes, select Scheduler, and then select Monitor Batch. For more information, see Monitor Batch.
- Select the Batch, MISDATE and the Batch name. Select the latest execution and click Start Monitor.
