Creating Hierarchy Definitions
To create a Hierarchy Definition in the Hierarchy Summary page, complete the following steps:
- Click Add in the Hierarchy Summary page. The Hierarchy Details page is displayed.
- Enter the Hierarchy Details as described in the
following table:
Table 6-11 Field Description
Field Description Name The unique Hierarchy Definition Name.
You can enter up to 100 characters. All characters are allowed except " & ' and " ' ".Description A brief description about the Hierarchy Definition.
You can enter up to 1000 characters. All characters are allowed except " & ' + @ and ~.Folder Select the Folder in which the Hierarchy is to be stored. Dimensions Select the Dimension to be associated with the new Hierarchy Definition. Click Apply. Hierarchy View The Members associated with the selected Dimension are displayed.
You can sort this list in Ascending/Descending order, expand or collapse the list to view in details and search for a specific Member.
You can focus on a Member to view the Member Properties.
You can add a Child or add a Sibling to an existing Member in the data grid.
Search View The search results based on the specific keyword entered to search a Member is populated. Table 6-12 Viewing interactive options for a Member
Icon Description Mouse-over a Member to see the following options. Select the required option to take action such as adding a child, deleting a node, paste as child, paste as sibling Figure 6-13 Add child, sibling, and leaf
Add a child, sibling and/or leaf. Figure 6-14 Create and add
Create and a child, sibling and/or leaf to the Member. Figure 6-15 Delete/undo delete
Delete a node or undo deletion. Figure 6-16 Cut and paste child/siblings
Move child/siblings up or down as required. To Add a Child to the Hierarchy:
- In the Hierarchy View tab, mouse-over the hierarchy to which you want to add a child and click the Add child, sibling and leaf icon.
- Select Add Child option. The Add Members page is displayed.
- Select the required Member and click Move
Right, to move the Member to the Selected Members panel. To
select multiple members, press CTRL and select the members.
The selected members are added to the Selected Members pane.
- Click Move All Right to move all members listed in the Available Members pane, to the Selected Members pane. Click Fetch from DB to select all nodes/ members in the server.
- Select a member and click Move Left to deselect a Member. To remove multiple members, press CTRL and select the members.
- To remove all the members from the Selected Members pane, click Move All Left.
- You can click Search button for the required member using Alphanumeric Code, Numeric Code, Name, Description, Attribute Name, or Attribute Value. Enter the search criteria and Click Search, in the Search Panel.
- You can also click Search button to toggle the display of Numeric Code left, right, or name and click button to display Alphanumeric Code left, right, or name.
- Click Add. The selected member is displayed as child under data grid panel in the Hierarchy View tab.
- To add a Sibling to the Child in the Hierarchy Definition:
- Mouse-over the child to which you want to add a sibling and click the Add child, sibling and leaf icon.).
- Select the option Add Sibling.
The Add Sibling Page is displayed.
- Select the required Members and Move
The Member is displayed in the Selected Members panel.
- Click Add. The selected Member is added as Sibling below the Parent under data grid Panel in the Hierarchy View tab.
- To add a Leaf under a Parent/Child or Sibling:
- Mouse-over the Parent or Child and click the Add child, sibling and leaf icon.
- Select Add Leaf.
The Add Member Page is displayed.
- Select the required Members and click Move
- Click Add. The selected Member is displayed as Leaf below the Parent or Sibling under Show Hierarchy Panel in the Hierarchy View tab.
- To cut and paste Child or Sibling:
- Right-click on any node and select Cut.
- Right-click on any node and Paste as Child or Paste as Sibling.
- To Delete/Undelete
- Right-click on the node to be deleted and select
Delete Node.
The node deleted is struck out.
- Right-click and select UnDelete to cancel deletion of the node.
Delete Node.
- To view the Member Properties and Member Attributes of a node in the
Hierarchy View Panel:
- Click on a Member.
The properties such as Alphanumeric Code, Numeric Code, Name, Description, Enabled, Is Leaf, Created By, Creation Date, Last Modified By, Last Modification Date, Attribute, and Value of the selected Member are displayed in the Member Properties and Member Attributes Grids.
In the Hierarchies page you can also:
- Click Collapse or Expand, to collapse or expand a branch .
- Click Focus or Unfocus, to focus or unfocus a selected node except the Root Node.
- Click Sort to sort the list in ascending or descending order.
- Click Save.
The new Hierarchy Definition is created successfully.
