Creating Prepayment Model with Rate Calculation as Integrated Model
In Integrated Model option, you have the option to select one of the already saved/confirmed Models.
To create a Prepayment Model Rule, follow these steps:
  1. Navigate to the Prepayment Model Summary Page.
  2. Click Add. The Prepayment Model Details Page is displayed.
    Figure 6-71 Prepayment Model
    Prepayment Model
  3. Enter the following details:
    • Name: Enter the name and a brief description for the Prepayment Model. The name you assign to the Prepayment Model must be unique. The name can hold a maximum of 30 characters.
    • Folder: Select the Folder
    • Description: Enter the description of Prepayment Model Rule.
    • Select Access Type.
  4. Click Apply.
  5. From Prepayment Model details page, select the Prepayment Model Rate Calculation Method as Integrated.
  6. Follow below steps:
    Selecting the Model for Prepayment Model Using Select Model section
    Defining the Structure of the Prepayment Model Using Dimensions section
    Modifying the Table Structure Using Bucket Definition section
    Prepayment Rates Using Matrix Definition
