Default Attributes
The following is the Default Attribute Summary screen, where you can find all the default attributes defined for various Product-Currency combinations.
Figure 4-62 The Default Attributes Summary screen
This screen includes the following sections:
- Core Product Attributes:
- Amortization Type
- Adjustable Type
In the Adjustable Type drop-down, if you select an option other than Fixed Rate, the following fields are enabled:- Interest Rate Code
- Adjustable-Rate Attributes:
- Repricing Frequency
- Repricing Frequency Type
- Rate Change Rounding Type
- Net Margin
- Net Rate
- Original Term
- Original Term Type
- Payment Attributes:
- Payment Frequency
- Payment Frequency Type
- Accrual Basis
- Interest Type
- Compounding Basis
- Holiday Calendar
- Holiday Rolling Convention
- Holiday Calc Option
- Remaining Number of Payments
In the Holiday Calendar drop-down, if you select an option other than None, the following fields are enabled:-
- Net Margin
Click Save to save changes or Cancel to discard updates.
