Generic Data Loader
The Data Loader service allows the user to load the required data by the Cloud Service to enrich the data. In this service, first you upload the data, and then run a batch to propagate the data into the processing layer.
To load the data:
- From the LHS menu, select Data Management Tools,
select Data File Administration, and then select
File upload and download to display the File
Upload/Download screen.
The File Upload/Download screen displays the list of files that are uploaded to the Object Store and displays the following details for each file:
- File ID: The unique file id. This is auto generated during upload.
- Prefix: The prefix added to the file name.
- File Name: The name of the uploaded file.
- Stripe Name: The unique identifier for storing the files.
- Uploaded Date: The file upload date.
- Download File: Click the Download icon to download a copy of the file.
- Delete: Click Delete to delete the uploaded file.
- Click Drag and Drop to browse and select a file
for upload from the local directory.
You can also browse to the local directory from the File Explorer and select file and drop it here.
The File Upload/Download service supports upload of TXT, DAT, and CSV format files.
Name of the data file must follow the format as given below:- A prefix as input_yyyymmdd where the date format is related to the As of Date (i.e., 02-May-2023 becomes 20230502).
- As per the data that you want to upload, upload the
relevant data file from the table:
Table 4-11 Data File
Loader type Data File Name Object Store File Name Exchange Rates stg_exchange_rates.dat input_20230622_stg_exchange_rates.dat Behavior Patters stg_behavior_pattern.dat input_20230502_stg_behavior_pattern.dat Payment Patterns stg_payment_pattern.dat input_20241024_stg_payment_pattern.dat Reprice Patterns stg_reprice_pattern.dat input_20241024_stg_reprice_pattern.dat Customer Master stg_customer_master.dat input_20251231_STG_CUSTOMER_MASTER.dat Customer Hierarchy stg_customer_hier.dat input_20260131_STG_CUSTOMER_HIER.dat Volatility Surface Rate History stg_vol_surface_rate_hist.dat input_20241024_stg_vol_surface_rate_hist.dat Economic Indicator Rate History stg_eco_ind_rate_hist.dat input_20241024_stg_eco_ind_rate_hist.dat Prepayment model stg_ppmt_model.dat input_20260303_stg_ppmt_rule.dat Prepayment Rule stg_ppmt_rule.dat input_20260303_stg_ppmt_model.dat Note:
The file name is case-sensitive.For more information about File Upload and Download, see File Upload and Download Utility.
The following are the sample files for reference:
- After selecting the file to upload, click Upload.
The UI displays a confirmation message Upload successful.
- From the LHS menu, navigate to Operations and Processes, select Scheduler, and then select Schedule Batch.
- Create a new Batch with a new Task with Generic Data Loader as
Component.
Table 4-12 Loader Type
Seeded Batch Component Loader Type Parameter Generic Data Loader Exchange Rates Generic Data Loader Behavior Patterns Generic Data Loader Payment Patterns Generic Data Loader Reprice Patterns Generic Data Loader Customer Master Generic Data Loader Customer Hierarchy Generic Data Loader Volatility Surface Rate History Generic Data Loader Economic Indicator Rate History Generic Data Loader Prepayment model Generic Data Loader Prepayment rule - From the LHS menu, navigate to Operations and Processes, select Scheduler, and then select Execute Batch.
- From the LHS menu, navigate to Operations and Processes, select Scheduler, and then select Monitor Batch.
- Select the Batch and then select the
MISDATE and the Batch name. There
may be multiple executions of the Data Loader batch. Select the latest execution and
click Start Monitor.
The UI displays the status of the batch.
For more details about Scheduler processes, see the Scheduler Services.
