How to configure Session Lifetime Timeout?
You can configure the Session Lifetime Timeout using your Identity Domain Settings in OCI Console.
Ensure that you have the Security Administrator Role mapped to access and modify the settings.
To configure the session timeout:
  1. Log in with your Security Administrator Account.
  2. Navigate to the Domain page. Click Settings and select Session Settings.
  3. Specify the Session Duration under Session Limits. Enter the required value. By default, this is set to 480 Minutes.
    Figure 3-5 Session Settings
    Session Settings
