Interrupting DQ Group Execution in a Batch
You can interrupt an ongoing execution of a DQ group in a batch using the Interrupt option on the Scheduler Services Monitor screen.
Perform the following steps to interrupt execution of a DQ group:
  1. Log in to the Service Console and from the left navigation pane in the Service console, click Operations and Processes > Scheduler.
  2. Click Monitor Batch from the Header panel.
  3. Select the Batch/Batch Group and the Batch/Batch Group Name that contains the DQ group you need to interrupt.
  4. Select the Batch Run ID/Batch Group Run ID.
  5. Verify that the Status is Ongoing as you can interrupt execution of ongoing groups only.
  6. Click Actions and select Interrupt.
The table below shows the status of the interrupt.
Table 4-24 Status on the Scheduler Services Monitor screen
Group Execution Scenario Initial status on the Scheduler Services Monitor screen Message displayed on the Scheduler Services Monitor screen Final status on the Scheduler Services Monitor screen
All requests are Pending Interrupted Interrupted Interrupted
Some requests are Pending and some in Success/Failed Interrupted Interrupted Interrupted
Some requests are in Pending and some in Success and Some are Ongoing Ongoing Partially Interrupted Interrupted
Some requests are in Success and some are Ongoing Ongoing Interruption failed Success/Failed
All requests are Ongoing Ongoing Interruption failed Success/Failed
