For Key Dimensions
The following is a list of sample files that you can use to build the Dimension Data.
The name of the Data Files must be same as mentioned below and the file extension must be .DAT. The value of column HIERARCHY_CODE must not contain space in files STG_DIMENSIONS_HIER_INTF, STG_HIERARCHIES_INTF and STG_HIERARCHY_LEVELS_INTF. HIERARHY_CODE must be in capital letters. Click on each Data File Name to open a Sample Data File.
Stage Dimension Loaders (Task 1):
- input_stg_dimensions_attr_intf.dat
- input_stg_dimensions_b_intf.dat
- input_stg_dimensions_tl_intf.dat
- input_stg_dimensions_hier_intf.dat
Stage Hierarchy Loaders (Task 2):
Any column description that contains a ",", then it should be enclosed within "" (double quotes). For example, Account, Type should be "Account, Type".To load the Dimensions:
- Define a new Batch and save it.
- Add the following Tasks to the above Batch:
Table 4-3 Dimension Loading Process Tasks
Task Code Task Name Component Parameters Parent Task 1 Stage Dimension Loader Stage Dimension Loader All parameters are automatically generated. 2 Stage Hierarchy Loader Stage Hierarchy Loader All parameters are automatically generated. 1 3 Stage DRM Loader Stage DRM Loader - Dimension Name: Select the relevant one or more dimensions.
- Sync Stage and
Dimension:
- Yes: The record(s) that is/are already present will be overwritten by the incoming dimension loader.
- No: The new records will be merged to the existing records.
- Force Member Delete:
This is used only when the above flag is Yes.
- Yes: This allows you to delete a members even if is referred in hierarchies.
- No: No records will be deleted.
2 Note:
The above Tasks must be executed in the same order.The File to Stage task must precede the Stage to Processing task in a batch.
The Stage DRM Loader allows you to select a Dimension.
- Execute the Batch.
This method of loading dimensions will be deprecated in future releases. Recommended approach is in the following section.
Dimension Loader with ZIP File Support
To to upload the Dimension data using a zip file:
- Create a Folder.
- Follow the naming convention for the DAT files as follows and save them:
- DIMENSIONS_ATTRIBUTES
- DIMENSIONS_BASE
- DIMENSIONS_HIERARCHIES
- DIMENSIONS_TRANSLATION
- HIERARCHIES
- HIERARCHY_LEVELS
- Place all the DAT files inside the folder.
- Zip the folder.
- Create a Batch.
- Create a Task with the Component name as Dimension and Hierarchy Loader.
- Enter the Zipped Folder Name along with the extension. For example, DIMENSIONS.ZIP.
For detailed instructions on Creating a Batch, Defining a Task, Execute the Task, and Schedule a Batch, see Scheduler Services.
Attributes Of Key Dimensions
Data for mandatory attributes of Key Dimensions must be provided in the STG_DIMENSIONS_ATTR_INTF file.
Table 4-4 Attributes of Key Dimensions
| Dimension Id | Dimension Name | Attribute Id | Attribute Label | Attribute Name | Attribute Data Type | Attribute Dimension Name | Mandatory Attribute? |
| 0 | Financial Element | 5000 | WEIGHTING_FINANCIAL_ELEM_ID | Weighting Financial Element | Dimension | Financial Element | N |
| 0 | Financial Element | 5001 | ACCOUNT_TYPE_ID | Account Type | Dimension | Account Type | Y |
| 0 | Financial Element | 5002 | AGGREGATE_METHOD_ID | Aggregate Method | Dimension | Aggregate Method | Y |
| 0 | Financial Element | 5004 | COLUMN_PROPERTY_ID | Column Property | Dimension | FE Column Property | Y |
| 0 | Financial Element | 5050 | ROLLUP_SIGNAGE_ID | Rollup Signage | Dimension | Rollup Signage | Y |
| 1 | Organizational Unit | 5030 | OFFSET_ORG_UNIT_ID | Offset Organizational Unit | Dimension | Organizational Unit | N |
| 2 | General Ledger Account | 5020 | ACCRUAL_BASIS_ID | Accrual Basis | Dimension | Accrual Basis | N |
| 2 | General Ledger Account | 5021 | COMMON_COA_ID | Common Chart of Account | Dimension | Common Chart of Accounts | Y |
| 2 | General Ledger Account | 5052 | ROLLUP_SIGNAGE_ID | Rollup Signage | Dimension | Rollup Signage | Y |
| 2 | General Ledger Account | 5057 | ACCOUNT_TYPE_ID | Account Type | Dimension | Account Type | Y |
| 2 | General Ledger Account | 5058 | RECONCILIATION_PRODUCT_ID | Reconciliation Product | Dimension | Product | Y |
| 3 | Common Chart of Accounts | 5040 | ACCOUNT_TYPE_ID | Account Type | Dimension | Account Type | Y |
| 3 | Common Chart of Accounts | 5041 | ACCRUAL_BASIS_ID | Accrual Basis | Dimension | Accrual Basis | N |
| 3 | Common Chart of Accounts | 5053 | ROLLUP_SIGNAGE_ID | Rollup Signage | Dimension | Rollup Signage | Y |
| 4 | Product | 5010 | ACCRUAL_BASIS_ID | Accrual Basis | Dimension | Accrual Basis | N |
| 4 | Product | 5011 | COMMON_COA_ID | Common Chart of Account | Dimension | Common Chart of Accounts | Y |
| 4 | Product | 5054 | ROLLUP_SIGNAGE_ID | Rollup Signage | Dimension | Rollup Signage | Y |
| 4 | Product | 5059 | ACCOUNT_TYPE_ID | Account Type | Dimension | Account Type | Y |
| 4 | Product | 5060 | AMENABILITY_CAT_ID | Amenability Category | Dimension | Product Amenability Category | Y |
| 4 | Product | 5061 | INT_SENSITIVE_CAT_ID | Interest Rate Sensitivity | Dimension | Product Interest Sensitive | Y |
| 4 | Product | 5064 | PRODUCT_LIFE_TIME_VALUE | Product Life Time Value | Number | Product | N |
| 5 | Legal Entity | 5062 | RATE_DATA_SOURCE_ID | Rate Data Source | Dimension | Rate Data Source | Y |
| 5 | Legal Entity | 5063 | GROUP_COMPANY_PARTY_CODE | Group Company Party | String | Customer Affiliate Category | Y |
Ensure that attribute values are present as members in their corresponding dimensions when an attribute’s data type is Dimension. For example, if the COMMON_COA_ID attribute for PRODUCT_ID 123 is 345, then 345 must be present as a member of the Common COA dimension.
